Flash Light stays on until reboot
fbxperia
Hello
My flash light does not go off after I turn it on from quick settings or after it is used by camera.
I have tried a number of things including factory reset but unfortunately without luck.
Can anybody help please?
14 REPLIES 14
profile.country.RO.title
_alexdon_
Did you use the inbuilt option from camera or a 3rd party app?
alexdon
fbxperia
Inbuilt option
_alexdon_
So you turn on the flash and if you exit the camera it stays on?
alexdon
fbxperia
Exactly and the same happens when I turn flash from quick settings
smia
Try to add the flashligt tog shortcut and stop The Light with that
fbxperia
That was one of the first things I tried but it does not shut off the flash
_alexdon_
fbxperia
Just tried your suggestion and I thank you for your help but the same occurs even in safe mode.
Booted the z2 in safe mode
Swiped down + quick settings + toggle flash light
Flash on
Toggle flash again
Flash still on
Opened camera + turned off flashlight
Flashlight still on
I hope I can fix this issue
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
alexdon
