Hello!
Tried to send you a letter with this form http://support.sonymobile.com/ru/contactUs/phone/?region=ru_RU
but the letter is not sent, but I filled out all the fields and put check mark.
Updated to Android 5, has its pros and cons, as well as the old bugs and mockery still remained.
Dear developers! Please take note of the below wording:
1. Lock Screen: Why is the space around the watch so not used economical?
even with an adequate clock widget in 1 row from the top stays more free space. - Not minimalistic!
2. The guests and the new user does not disappear system buttons in full screen (for instance in the game Clash of Clans) - correct!
3. Why did you create a new user name you entered does not change the list of users? - Correct!
4. Keyboard: Why your keyboard does not have quotation marks? «»
5. Why did not notice open with 1 click? !!! - Correct!
6. The button "Close all" in the application list looks awful, the text rests on the edge. - Correct.
7. Deleting files from a memory card - hoped that in 5 versions of this idiocy will not, but it still remains, return the application of the right to delete files from the card SD !!!
8. "Move data to SD-card" - give an option to disable this notice !!!
9. Notice: "Mobile data: Data off" - well, I do not use it !!! why do I constantly notice debility show? !!! - Correct !!!
10. I paid for your product a lot of money, as a result I got a smartphone with a bunch of unnecessary applications that I absolutely do not need, and which can not be removed !!! Please move all your apps from the system in normal, otherwise I will never in my life will not buy your products !!!
11. Often writes that: "Network not found" - but this is not true, there is a network up and running, is treated only entrance \ exit the flight.
12. The screen smartphone: Our family of 3 device, I'm disappointed in your company, all 3 smartphone under identical options brightness and color balance, in different ways display one and tighter picture, on my screen white color gives a lilac, my mother white as white, gives his sister in gray. Settings themes also same.
13. How do I reset the brightness to "default"? the colors were natural. - Not as I know, make a reset while holding brightness slider.
14. Do not keep the volume after a reboot.
15. Appendix "Contacts" - just awful !! so much time and neither can not seem get used to. At Samsung so easy! swipe your finger to the right and you call, swipe your finger to the left and writing sms.
16. Glitches with a headset (MEE A161P): use the headset is simply impossible! The old Samsung are no problems, but here instead play \ pause frequently opens and you SmartKey and instead decreases the volume of the next track. I tried to set up and all and kill your prog - but the headset still does not work properly.
P.S. I understand that a lot of the above described applies more to developers Googl, but lot depends on you.
P.P.S. Probably will move on CyanogenMod, his makes normal guys who are friends with the head and people.
We are a user led support forum and have to influence over Sony
