SD cards work in classes - So using even numbers only class 2 is the lowest minimum write speed at 2MB/s and the maximum is 10 been 10MB/s minimum write speed and inbetween you have 4, 6 and 8MB/s minimum write speed
Then you have UHS speed class of 1 and 3 which are the super speed sometimes refered to as U1 and U3 - U3 been the fastest at 30MB/s minimum write speed for use with 4K technology and U1 been 10MB/s minimum write speed - So UHS 3 could read and write at speeds up to around 90 to 95MB/s
Guys,I have recommended some time ago a class 10 Sandisk for someone with Z2.He said it works very well.
