Factory reset when touchscreen is not working
Raadush
Hi, I have this issue, touchsceen on my Xperia mini pro is not working so when I power the phone on i get to lock screen and thats it. I want to perform factory reset to find out whether its software or hardware problem, but how to do it, when I can't select factory reset in the menu. Tried couple of suggestions how to get into recovery mode, but none of them worked. Can somebody help me?
8 REPLIES 8
somebody
Try repairing it with PC Companion or SUS, this will reinstall the firmware & reset your phone.
Nayuta
i think update using SUS wont work. T have tried many times to flash and repair it but my mini wont work anymore.
profile.country.PH.title
MarlonUk1
try to perform a service test dial *#*#7378423#*#* then under service test, select touchscreen, see if the screen is reponsive to all commands.
if your problem happens during when the phone is hot. you might want to visit your local service center to have your phone checked. http://www.sonymobile.com/global-en/support/contact-us/
Raadush
Ok, ill try suggested. Can you just tell me one more thing? How can I backup my contacts without working touchscreen. Companion always says "now disconnect phone, select setting, backup..." and that's what I cant do without working touchpad.
Thans
there isn't a way to do so, as if you want to install an app you need the touchscreen to enable them, have you synced with google?/
Raadush
No, its my girlfriends phone and she dont know how to use this stuff Winking_Face Strange there isnt a way really Neutral_Face It shouldnt be such problem to access adress book through pc.
there are myriad apps on the market to do so check
"My Phone Explorer"
or just sync with google and you can access your contacts through your gmail
is Sony spying on users in this forum?
http://talk.sonymobile.com/thread/60197
UNRELATED topic, if you have some time please check this thread
http://talk.sonymobile.com/message/244522#244522
