@Sheroo You have already perform a factory reset according to your older posts.
Indeed a factory reset will erase all internal memory.
Hi Sheroo,
Just to add here, a factory reset only removes content from the Internal Storage(unless specified during the process). So if you are trying to remove content from the SD card, then this is not the best option.
Let us know, what exactly you are trying to achieve so we can help further.
It will be recreated, but that's for your photos from SD card.
Yes, as far as I know thumbnails are created for every image you have on your device, unless there is a .nomedia file in a folder.
