Facing problem with Soft keys ? Need help
Hi everyone,
I'm using Xperia Mini for the past 1month & sometime I'm facing a problem with my soft keys ( Back & Settings touch keys ), which is automatically working. I cannot able to open any Application, it automatically comes back to home screen (Back key keeps on Vibrating) .. Does anyone facing this problem & wat's the solution ?
18 REPLIES 18
santam1
hi @devaruban i'm also using XPERIA mini haven't got this issue if you your using haptic feedback then I would recommend you to change the setting of haptic feedback for this go to setting>sound>scroll down a uncheck the haptic feedback.....and see whether the issue stops......   don't forget to mark my answer correct and helpful...
Hey i also have same problem with the mobile. Mine is Xperia Mini Pro white and sometimes, the soft keys are pressed automatically, and im not able to navigate at all.
First my vibration for soft key option was disabled and so i was not able to understand its because of soft keys. Afterwards, when i resetted the settings, i found that the phone was vibrating when the problem occured. So the conclusion is that the soft keys are getting pressed automatically.
@sanatam: I dont know if it will solve because initially my phone, that option was disabled and i had the problem then i resetted the entire settings and found that the phone was vibrating.
Anyways ill try that if the issue gets resolved, will inform back...
santam1
hello @sriramAS what build number ur using could you please post it!! go to setting>about phone then build number...
Model: ST15i
Build: 4.0.2.A.0.62
Im having this mobile for the past 3.5 months, i didnt got any problem, but suddenly im getting this problem. I have updated my software atleast 2 times after i bought the mobile. Dont know if update is a problem or something else...
I disabled haptic feedback, but still its not solved. I guess the softkeys are getting pressed against something. Sony ericsson service center is also a bit far from my home. Slightly_frowning_Face
The worst thing that i had was, i had a pattern to unlock my mobile and since the keys are getting pressed constantly, before i could finish the pattern, the prompt entered with a wrong pattern. Many times i had to try it out inorder to unlock my mobile.
Message was edited by: SriramAS
Yes Sriram, the same kind of problems happened to me. Me too went to service centre & they recommended me to re-install the software. After that it works fine until now, but I'm not sure whether i'l  get the same problem again.
So what will be the permanant solution for this problem ??
What do you mean by "re-install" software? Setting-->Privacy-->Factory data reset or Settings Reset??
santam1
@sriramAS and @devaruban...repair your phone with SEUS here's the link download it and install it on your pc and go through the process... http://dl-www.sonyericsson.com/cws/download/1/110/61/1309763183/Update_Service_Setup-2.11.7.13.exe                   *please note this will delete all your user data on phone except sd card  and sim
and keep me update with after repairing with this software...                 and don't forget to mark my answer as correct and helpful
boyzrulz52
connect ur mobile to pc companion and press software update it prompts for software repair accept it before doing that backup ur data to memory card
@Sriram I mean after I formated my OS , the issue got cleared. Thank you for all your responses.
