Notification area at the top of screenshot of my phone shows the issue which i'm facing.
Even I am having the same issue. Please someone help us out
Strange! Haven't seen or heard anything like this before.
Have you tried to restart your phone and remove the battery for a while? Otherwise I suggest that you try to update/repair the phone software using PC Companion:
Yes Alexander,
Its true, the notification bar renders like above sometimes,but will become normal after doing display on/off. Its observed in Latest version only(v0.36). Will become severe bug if there are applications that uses notification bar frequently.
I'm facing this problem as well.
What I've noticed so far is that it only happens if you are connected to the internet and especially when you initiate a download.
I tried the batter removing thing and I think it worked, I haven't seen those lines so far.
