facebook inside xperia problem
i can never sync it since i upgrade to ics
always display 'sync error' and 'sync is currently experiencing problems. it will be back shortly'
and also profile pic in Contact does not sync with facebook either.
anyone have the same problem?
4 REPLIES 4
Markus1
Leader
Go to Settings > Apps > Manage apps > tap on the tab All > scroll to the bottom. Check if you have any Facebook plugins/apps here that are inactivated. If you do, tap on them and then tap on Activate.
For the contact picture issue you should start the Facebook app > press Menu button > Log out > Start the app again > Log in > Choose the option to only sync with existing contacts.
Do this when connected on WiFi if possible since the phone will delete all FB data and then re-sync it. Might take a while so WiFi should speed it up.
Let me know.
Ris84
I have the same problem. My FB inside Xperia is Sync Contacts 20 min and continuing doing same, but nothing happens. Contacts dont have pics. I try to delete acc and to reset fb but is the same.
Not all my facebook contacts are synced with phonebook. I tried removing the account and adding it once again however its still the same
xeres09
Hi everyone, I have a problem. I can't use Xperia with Facebook Using my Xperia Tablet Z Wifi... I just want to post photos on my main facebook account with at tag below "Via Sony Xperia Tablet" and save it in a
Xperia Album automatically... In my main Facebook account I can't use it. But why is that when I logged in with my other facebook account it does...??? I only use One facebook application. I only switch them when i like to play games... PLease help me guys.... Slightly_frowning_Face
Hope anyone can help me... Thanks in advance.
