eXT mEMORY cARD
rahul3103
eXT mEMORY cARD
I have 2 GB Sd Card which is working fine in my Xperia Sola.
But when I connect my phone to my PC and choose 'connect SD card', still the only drive I see is phone's 4 GB Internal storage drive.
Problem persists from the beginning. The SD card's drive is never shown, no notification in windows about its detection.
I am running Windows 7 - 64 bit.
I went through some of the forums and saw people mentioning this to be driver or missing .inf files problem in some PCs but driver details or file names were never mentioned.
I have disabled/enabled,uninstalled and reinstalled Xperia Sola device and its drivers, but the issue still persists.
Also tried with MSC and MTP modes.
Johan
If possible check if the same problem can be replicated using another SD card. If yes, I suggest that you contact your local support team to have your phone examined and fixed at an repair center.
