Experia Z2 hard locked problem
YACIN
Hi
I have Xperia Z2 ...I can't access My SIM.....and also it is Hard locked and the PIN is not acceptable...my IMEI is
and the problem is this : [x] network 0
...Please help
3 REPLIES 3
CameronT
Hi @YACIN,
Welcome to the community.
The 'x' means that the phone you bought is locked to a network, and the number after it tells you have many attempts you have left at entering the correct unlock code. 0 means that wrong code has been entered 5 times, so even with the correct unlock code, you will not be able to remove the network lock from this phone.
I can only recommend you contact the network the handset is locked to, or the retailer you purchased the handset from.
YACIN
thnkx Mrs CameronT ...:smileyhappy:
CameronT
@YACIN,
Any time Slightly_smiling_Face
