error occurs in emma software when we connect more than 1 device at a time
faihearts
how to troubleshoot this problem, please give me a solution
Rickard
Select USB3 on the left side in Emma and make sure that the checkbox on your screenshot is not enabled. When it's enabled you can only connect a C2305 that's compatible with that software version and it seems you're connecting a phone that is not to USB3.
If you still get that message, try rightclicking USB3 and deregister it and then try again.
If that doesn't help i recommend that you contact our support for Emma. Select Help -> Emma Web Site -> Make a support request.
