Hi
Suddenly I couldn't turn on wifi hotspot and BT. so i decided to upgrade to ICS and i now regret it very much.
I did it using update service from SONY. went fine until trying to turn on wifi then phone restarted and kept restaring in a loop. I had to do a hard reset and repair it using the update service. again it went fine as long as i dont turn on wifi, then the phone restarts again and again in a loop. tried to repair using SONY PC companion, but same problem exists.
Now I wish I didn't do the upgrade!
PLEASE HELP!!!
all the best
Rami
If the issues continue after a software repair I'd recommend sending your handset for service so it can be examined. Repair details can be obtained by contacting your local support team directly. You can find contact details here: http://www.sonymobile.com/global-en/support/contact-us/
Hi, exactly the same problem I am facing after sw update. As soon as I try to turn on the wifi, my phone goes to an indefinite loop of on off.
Can anyone help on this. Seems its common problem, nd should have a solution.
