The other party gets echo when i put z2 on speaker. The speakphone is almost unusable, eveyone compliants. I'm disappointed with this. Is there a solution.
Even the speak volume on a call is low compared my previous phone.
Do you have microphone noise suppression enabled?
Exactly the same with me the other party can barely here me due to all the echo, tested the mic on top of the phone today and this is where the problem lies as it is just to close to the earpiece, if sony could just bring out some new firmware that can deactivate the top mic then it will be fine. tried using headphones and sound quality of the call was great, also i turned off noise suppression in the call settings as this made my voice sound like a helicopter
I tried toggling microphone noise suppression, but the problem persists. When i enable microphone noise suppression following message appears "Microphone nice suppression works only when you talk directly in the phone, not when you use the speaker or headset". Which means microphone noise suppression has no impact on speakerphone mode.
There is also an option for speaker called speaker voice enhancement.
