Earphone problems
KernowMan1968
Earphone problems
I have a problem when I use earphones (MH750) with the Xperia Z1
The problem started about 2 weeks ago
I can hear music through them, but when I want to change tracks and anwser a call it dosn't work.
The earphones work fine on other Sony mobiles
Has anyone else encountered this problem?
4 REPLIES 4
Sophia
Not only the iPhone , nearly every headphone has it's functions just like the picture. If your headphone works well on other phones, you should use a new headphone try again on your Z1 at first. If can't work well still, that's your earphone jack may has something wrong. You can consider to replace with a new one.
KernowMan1968
The earphones are the ones that came with the Xperia Z1
Like I said, they work on other Sony Mobiles, I tried them on different mobiles in the store
Tried  a friends set on my mobile with the same results
Its really Pi***** me off
Sometimes the earphones works fine for 30 mins or so
The they seem to lock up again
So it must be a phone problem
rency_07_22
I have the same headset (MH750) and NO encountered issues so far from earlier FW (526) to the latest 4.3 FW.
You should bring your phone to the Sony center for checking.
shei
It is not possible to answer or end a phonecall, turn up or down the volume. It's like it didnt work as a handsfree set!!!
Why?? It's too expensive to malfunction in that little detail.
Help!
