ear speaker not working
earspeakernotwo
Past day the ear speaker on my xperia z1 stopped working I have to use loud speaker to hear anything any suggestions thanks
3 REPLIES 3
profile.country.RO.title
_alexdon_
Try settings-apps-all-smart connect,force stop and clear data. Restart.
alexdon
earspeakernotwo
Thanks I tried it and it did not work
_alexdon_
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery.
alexdon
