E3 freezing
Brambles
E3 freezing
My E3 has recently started freezing randomly.
When it does I am unable to use the screen, switch the phone off or reset. The only way to reset is to remove the sim and replace it.
I have searched many forums, and many people have a similar problem.
Some say it is due to the memory, but I have over 500mb free.
Some say it is the Micro SD card causing the freeze.
I have removed this.
Has anyone any ideas what is the cause of the freezing.
2 REPLIES 2
Thommo
Genius
I'd consider performing a system repair but this will factory reset your phone
Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the onscreen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process
_matti
my xperia E3 is also freezing i did a software repair via PC Companion but the phone only works for a few hours then it starts freezing again. Help!!!!
