Does the problem occur once in a while or for every call? If once in a while, the problem is probably with the network- it probably happens to everybody at one time or the other. If it occurs for every call, then your phone may need to be repaired. Also try your sim card on a different phone or a different sim card on your phone.
Yes,could be the network.Do you have good coverage?What network settings do you use(2G/3G)?
