lately my phone when it is idle on when costs need to use it or answer a call. Unresponsive. the screen is not damaged or burned because shuts down and turns perfectly, but when the idle screen does not turn off. What can I do?
Often a screen protector or case can interfere with the sensors so if you have those you may have to remove them and try again. It is also worth performing the test in safe mode after you have removed any protectors/case.
