1) Why not you also lunch unbreakable and flexible display in your smart phone, like Sony xperia z ultra
we heard from internet that Sony shown flexible screen wrapping on the pencil made for smart phone in 2010,
but still not lunch for commercial, why
Samsung, LG, IPHONE planning to lunch unbreakable and flexible screen for smart phone.
2) we want Sony back with good smart phone, not the one you lunch Sony xperia z ultra
From your side you made a cheap material display screen and fragile
For us more problem in maintaining the fragile screen and by changing the screen again and paying more.
We want Sony xperia z ultra same 6.4" screen side and more thinner than 6.4mm of z ultra,
make flexible display with stable frame and bigger battery size of 5000 MHz.
ZXU is the thinnest and largest full HD smartphone available in the market. In interview with the Z ultra-research team chief about what are challenges faced while designing XZU. Initial plan was to design the thinnest smart phone using parallel chipset battery method used in tablet design but incorporating it in the 5.6' phone is inefficient as this leds to small battery. So they went ahead with a slightly larger display ie 6.4' with high density battery. Along with a illustrious tri-luminous display, iconic water proofness and legacy quality by packing whole package in between two sturdy glass and aluminium frame resulted in ZXU.
In fact if they went for a thinner it will lead to a brittle device with less battery or need a thinner higher density battery with again leads to higher charging time. Flexible display is an unfinished technology, it has serious limits, if Sony would have incorporated that in XZU we might not have a gorgeous tri-luminous display. Most sturdy phones I seen are iPhones, Nokia and HTC one to be frank I love thinness above a fat brick.
