Disappearing data problem
milcz
So I have the Xperia J with android 4.1.2 and recently i have noticed a very annoying problem. Every once in a while my phone stops recognizing any data stored on the sd card. The album is empty, the ringtones change to default, all playlists and music disappear from the walkman. The apps and stuff are working fine. Rebooting the phone does not help. It eventually comes back on it's own but as you can imagine it's driving me crazy. Especially since the most recent disappearance has been going on since yesterday morning. It seems like each time it gets longer. Also, after plugging my phone into my computer neither the windows explorer nor mediaGo recognize ANY files on the SD card or the Internal storage. All my music and photos are saved on the sd card but i'm pretty sure that the data from the internal storage disappears too. But the apps work fine. When i open an app for cleaning it sees all my files, and both the phone and the computer (when the phone if plugged in) recognize the space that all those files take up. They don't exactly disappear, the phone just refuses to read them. I don't know what other specs of the phone might be useful, I can even list all my apps if it might be a factor.
I would greatly appreciate ANY help Slightly_smiling_Face
19 REPLIES 19
aisling
I have this exact same problem with my Xperia J. At this stage the photos appear for a day or two if I'm lucky and then disappear for a week or more. The same problem has happened to a friend of mine. If this is a common fault shouldn't there be some sort of compensation or free repair?
profile.country.RO.title
_alexdon_
Do you have any task killer or antivirus?
alexdon
Princey
I've got this problem again. It's happened to me three times now, and It's driving me insane, because I don't know what causes this to happen. I've done an update, cleared all my cache, downloaded E.S File Manager and done a system refresh ( which worked for me last time ) And now what? I'm running out of options.
_alexdon_
You should visit a sony service:
alexdon
Amsyar
Sony mobiles support only sd memory card
of sony.
It means they do not support other company
sd cards which other companys' mobile
support.
So if you are using third part memory card
then you have to buy original sony sd
memory card.
Check that one in shop first then purchase it.
I think your problem is solved.
thebuzzingbee
I have a problem with my Walkman app on my Sony Z2.
I add songs to my phone which then go to the newly added play list, at this point they are in my songs library. When I then download a new bunch of songs, the previous bunch go completely missing from songs library etc. I've tried searching for them using the search tool but they are not found.
Please advise on my issue!! It's really annoying because half the songs I download go missing....
Anyone had a similar issue?
thebuzzingbee
All songs** go missing
mcbrideryan1
The problem doesn't lie with the card itself but with the phone - It doesn't read the internal memory nor the SD memory! The PC companion won't make a difference. The missing files disappear for a time but then reappear after a while - I cant have this happening! It's frequent and it is not what i expected when i bought the phone, an Xperia J.
Clearly this is a common issue with these phones, judging by this and many other threads, and if you cannot provide us with a real solution other than this cop-out of making us download your PC Companion software I expect to look after my consumer rights and look for a phone that isn't faulty, from another brand, that I'll get my moneys worth out of!
Now please, what useful advice can you offer us about fixing this problem once and for all?
requiescence
I have the e4 and a mac computer I'm using a genuine San disk and yet every time my phone shuts down due to low battery it turns on and the icons cannot be found. Google play says they are installed and "downloaded" says there are 34 apps but I can only see two. why opened from Google it's clear the phone can access them the shortcut icons just don't appear. how do I solve this?
requiescence
I'm not buying a new sd card either if you're going to suggest that find another way
