Dialer & Contacts are crashed in my Xperia L and its not opening at all.
Any help to restore them.
Do you get any error message when trying to open the application?
The error shows as application has stopped unexpectedly. There are no other errors.
Go to setting>apps>all>Contacts>clear data
Go to setting>apps>all>Phone>clear data
Then restart your phone..It should fix the problem..
Will this resolution wipe off the data in the contacts? will i lose the numbers stored in the phone?
No, contacts are stored in the app called contact storage. As long as you don't clear data for contact storage, the contact will not disappear.
If you uninstall Facebook and WhatsUp it should work. Make sure that you don't synk your contacts with Facebook if you decide to install Facebook again.
I think Facebook is the main problem, Do the following step:
from setting, accounts & sync settings then remove all accounts except gmail account.
phonebook well work, when I try to add facebook account again the problem appears again
I had remove facebook account and now my phone is working well
We have identified this issue on some units and the source of issue resides in a Google Play Services update (4.4.49). Google has been contacted about this and have confirmed a fix for Google Play Services version 4.4.50 or higher. In the mean time you can either remove any accounts that depend on Google Play Services like, Facebook, Viber, Skype etc. You can also choose to uninstall the latest Google Play Services update but then losing access to some Google applications.
