Hallo guys,
I would like to ask you how can i enable the diag mode in xperia x8? i have tried the ##3424# but it did not work.I would really appreciate your help in this.
Thanks in advance.
Are you you referring to the service menu? Try *#*#7378423#*#*
Hallo,
i am not sure what the service menu is.I tried it though and nothing happened.I am trying to connect my phone to the pc and i want to see the com port that is using.In order to see this i have to set the phone in diagnostic mode. Actually i saw this from this video:
okay i see, but i think you need your phone to be rooted, o ri think it only works on cdma phones..
i have tried the 3424 code on a rooted xperia..so you say this can not be done on xperia x8?
I think it only works on cdma phone just like it says on dthe video.
ok thanks..and what is a cdma phone?
Access hidden testing menu on your Sony Ericsson Xperia X8 (E15). This secret service menu allows you to check if your Xperia phone is network locked. Moreover you can check if your phone is permanently blocked or you still can type your unique unlock code!
Just type secret sequence:
on lock screen of your phone.
Just found out this on youtube!
Edit: Someone in the posts posted that this works on any custom ROM:
Just type this in the dialer: *#*#4636#*#*
source:
