Hi all:
I have a Xperia mini pro. I'm very happy with it but I found some issues. One of them is that the mp3s I've selected to be the default ringtones (located on the SD card) are changed from time to time and I have to re-select them again and again.
Is there a way to fix this?
Thanks
This should not happen and with this being the case I would advise running a software update and choosing the "Repair" option when offered in the process.
Hi Sam:
Thanks for the reply. Which would be the process to be followed in that case?
Thanks
and install it on your PC.
4. Phone Software Update.
5. Start.
6. Repair Phone
7. Continue
8. Accept data removal
9. Next
10. Wait for prepare
11. Select Phone
12. Follow the connectionn steps
i had the same problem and i did a wipe with SUS and that didn't solve the problem either...
Sam! Please help fix this. Even I have the same problem. Here is the thread I created: http://talk.sonymobile.com/message/259443?tstart=0
