Data usage
EricChan
Data usage
How can reset the data usage period? I cannot find the setting.
3 REPLIES 3
profile.country.RO.title
_alexdon_
I do not think that can be resetted,just drag the bars closer to each other and you will get no use.
alexdon
EricChan
I know the previous version can set the bill starting date.
Jake-SonyXperia
HI EricChan,
With the information supplied, I can advise that the Bill cycle option is still a function within the Data Usage. Simply tap on the option that states Data Usage Cycle. From here you can change the dates.
I hope this helps.
What are your thoughts about this forum? Let us know by doing this short survey.
