Customization number
LostSouls
New
Hey guys. So, It seems like my Xperia Z3 has the firmware from the Customized ES version. However, atm I'm using it as Vodafone PT, so I wanted to change the customization number from the Customized ES (1288-8882) to the one from Vodafone PT (1289-4163). Is there a way to change it?
3 REPLIES 3
Thommo
Genius
Yes but you need to root your device and use an app called build.prop editor however the easiest way would be to download the firmware and manually flash your device
LostSouls
New
Can you tell me the best way to root my phone?
Thommo
Genius
Why do you want to change the number? if it's so you'll get updates then it won't work as your phone will be seen as modified - The easiest way is manually flash your phone
