Cracking Sound Problem !!
write2vivek86
I have discovered a cracking sound problem if the volume of the phone is set to high, but when i turn off the xloud enhancement, everything works fine, with xlound turned on i have to keep the sound lower from the max, however turning it off gives no problem, so this is not a hardware problem i guess, anybody facing the same..??
4 REPLIES 4
Sam
Legend
Legend
Have you attempted a software update/repair?
Raja22223
Hi Sam,
Its a Known Issue and facing by Many users you can find the same in Form.
With the Software Repair it wont Solved.
Kindly Adress the Issue to concern department and get the Solution.
Thanku
write2vivek86
Raja is right, the phone sound issue still remains just like it was, though i have done update/repair from sony companion. However i knew it will not go away, but i had given a try. Now please give us some update for ICS and correct the issue..!! Thanks..
aayushjain1987
You are one of the many ignorant persons posting in this forum .
I have provided 3-4 times reason and solution to this problem, Only if you have cared to search in this forum.
Its neither your hardware problem nor your software. you can repair endless number of times and replace the handset, many number of time. Your problem will not get solved.
Search for the solution in this forum.
I wish moderators have enabled strict posting criteria like XDA FORUMS to force users to search existing topics first, rather then creating new topics for same problem & solution posted 100 of times !!
