Correct white balance against blue tint Z3 Plus
Alessio_841
Hi Community,
The display of Z3 Plus has a blue tint in greyscale, according to reviews using CAIMAN software.
Which are the correct values, in the white balance settings, to have a correct greyscale and more natural colors?
I hope in a any answers.
Thanks
6 REPLIES 6
Could you elaborate in regards to CAIMAN?
Alessio_841
A review had used CAIMAN and colorimeter to establish the not good RGB balance in the Z3 Plus display with a greyscale tending to blue tint very much.
http://www.notebookcheck.net/Sony-Xperia-Z3-Plus-Smartphone-Review.146123.0.html
So, which are the correct values to set in white balance menu setting to have correct white?
Or, alternatively, how calibrate accurately the display using the smartphone?
Thanks
Lord_viridis
Personal taste, play with the values until you find a white you like, for me it's red +70, green +50
Alessio_841
I don't search a personal taste, but a correct values for reproducing the colors as correct as possible, especially when see photos.
Roberto17
I think it's enough to increase the green color just little bit?!
Alessio_841
Without a colorimeter it's impossible to set correctly the RGB balance of the display!
Bluish tint can be the "side effect" of the Triluminos technology that uses blue LED instead white LED?
Why Sony doesn't give a tool to calibrate the display? There is no sense have white balance option if there is not a referiment!
