my xperia l starts vibrating suddenly when battery is inserted. . even before turning on .. . it just stop when the battery is removed . . can any one say some way to fix this problem
this problem persist from the time when my mobile got into water . . . can i proceed the same steps . .
You can try but most likely this is a hardware issue, take your phone to a Sony repair center.
thank you. can you please solve my confusion. . whether it is a minor or major fault in hardware . For your information , that is the only problem that prevails in my mobile. inspite of that all other functions are very normal . phone is getting on , videos get played, .etc. . .no other issues but it doesn't stop vibrating . . Can this problem can be rectified ?? it is minor or major hardware problem
I can't answer that question, the phone has to be open to see the damage.
Thank you . . I took my mobile to service centre. They said that the board is shorted . The only way is to remove the vibrator. But a bad thing comes then, they said that if they remove the connections of vibrator, they may also remove the connections of mic and led , because they all are connected together. I don't know what to do
I'm sorry I don't have any more suggestions
