contacts unmatched
contacts unmatched
I don't know whether you all are having the same problem here. For instance, you have a contact named ABC 0161234567
When you dial the number, it shows you are making a call to ABC. When you receive a call from ABC, it shows ABC as well
However, when ABC sends a sms to you, and when u go to your inbox, you just can't see the name ABC. Instead, you can only see +60161234567
Can anyone help me to solve this problem? Thanks in advance
I have the same problem
