Hi there! I've got a little problem... Recently I had to do a factory reset and since then my contacts images work no more... The point is that now the images are small images.
Before that I had half-screen images during call time and a big image on the top of the screen when I was looking at contacts profile... Now I just see a small image on the top left corner... If I select a new image it seems working, but after a few minutes it doesn't work again
Could anyone help me?
Which build number are you running on?
Settings > About phone.
Have you tried to reinstall the phone software using SUS?
If not I suggest that you try and check if the contact pictures still look the same.
