Connection problem
gostapalmer
Connection problem
My Xperia x8 wouldn´t charge after 1 year of use so I had it serviced.
(Detail: 10 remaining days of warranty but service refuced to fix phone as connector was broken = sign of violent and 'bad' use. Ridiculous! With todays´s smartphones you´re supposed to use them as sound systems, appointment book, GPS, phone book, radio, youtube and what have you. Hence, you need to re-charge 2-3 times a day.)
Anyway, after it got back to service it wouldn´t connect to the computer anymore via USB. The computer simply doesn´t recognize it. And one more thing, when I download apps they all work correctly WITH ONE EXCEPTION. I use speedometer/radar warning and with GPS signal active it reads the location perfectly, i.e. shows location with street names etc. but the speedometer won´t work. I´ve tried 3 or 4 different apps for the same purpose with the same result. GPS reading works but speedometer doesn´t.
All help appreciated
2 REPLIES 2
Johan
Has the speedometer been working before?
Could you clarify, did your get repaired or not?
gostapalmer
Hi Johan
Yes, the speedometer worked like a dream. I was using it all daily as I have an old car and the speedometer doesn´t work.
And yes, the tecnician fixed the connector so now it charges and all other functions work except for the data transmission via USB. But via Bluetooth it works.
