connecting to bad usb voltage deviation
omid237
I connected my cellphone to bad usb and voltage deviation cause to shut down my phone and now I can not turn it on. is it out of service? it will be repaired ? what can I do?
3 REPLIES 3
Rickard
Sorry to hear about your phone.
Try holding the off-button under the back cover for a few seconds with a pen or similar and then let it charge for a few hours using the standard charger and see if that helps. If not i'm afraid the phone may have been damaged and needs to be examined and fixed at a repair center. For more information about how to submit your phone for repair and where, contact your local support team.
omid237
MY xperia SL dosenot have off botton back of cover. but I hold off top bottom and charge it but it was not nurned on and it make warm and hot.
Rickard
I thought you had an Xperia SP as you posted in the SP forum. I've moved the topic to the SL forum instead.
On the SL you can try to hold on/off and vol+ at the same time for 10 seconds instead. If that doesn't help you need to contact a service location or your local support team.
