Connect car's radio using USB
SilenceWhisper
Well I tried to connect my phone to my car's radio . The radio shows USB ERROR. My phone shows internal storage connected to PC.
7 REPLIES 7
Ashroft98
Enthusiast
Try this
Go to Settings > Xperia Connectivity > USB Connectivity > Change Media Transfer Protocol to Mass Storage and try reconnect.
SilenceWhisper
All I see in USB connectivity is Install Pc Companion and No Trusted Host
The Xperia S/SL/AcroS doesn't have that option
SilenceWhisper
So Xperia S able to connect to car's radio or not ??
I don't think you can use the USB to connect to your radio but a 3.5mm cable
http://talk.sonymobile.com/t5/Xperia-S-SL-acro-S/not-supporting-aux-and-usb/m-p/163740/highlight/tru...
Community Manager
Johan
Re: not supporting aux and usb[ New ]
Xperia S uses MTP mode for USB connection and the reason why is doesn't work is most likely because your car audio system doesn't support MTP devices. My best tip is that you check if your can use a 3,5mm audio cable instead, to listen to your phone music in your car audio system.
SilenceWhisper
Okay thx.
