Compass issue
Elmo5
Compass issue
The compass in Xperia SP doesn't work. I'm using SwissArmyKnife app, and the compass doesn't move at all or shows anything but true readings. I think it was quite trustworthy with Android 4.1 but 4.3 update messed it up. Any ideas how to fix it?
This issue is perhaps not so significant compared with severe lagging, touch screen sensitivity issues and screen flickering, but I think it confuses heading direction within Google Maps.
Have done software repair with SUS and have reset to factory settings several times. Have also disabled most of the Google services. All of the mentioned workarounds have helped for a while but eventually all the other issues have come back, except compass hasn't worked at all since the 4.3 update.
7 REPLIES 7
Larek
Mine doesn't work either, and don't know anybody with SP working compass
daverawle
My compass works fine on .201 using GPS Status
Dave
gstech10
well.. mine is working correctly both in swiss army knife tools and compass lite app.. updated to latest 4.3 version.
Elmo5
I've tried also some other apps but without success. I'm quite positive it stopped working abt the same time as 4.3 update.
Could it be a hardware issue though?
Danial-mach1
Leader
dial
*#*#*7378423#*#*
then goto service test>compass...see it work and try to calibrate it
Elmo5
It doesn't help either. Compass reading is between 350 and 360 no matter where I point the handset.
Elmo5
Found the fault after nishan256 asked if it was safe to use a magnetic pouch. Of course the magnet confuses the compass. Thanks nishan!
