Hi
Have been having an issue with the clock on the phone. It doesn't update until I unlock the screen, where I can then see the last time I updated from(I checktime at 9:20pm last night, the next morning it shows that for a second or 2 and then updates to real time.
If you check it within the time on the phone (before your "Disable alarm timer" is set) so it updates into the alarm set time, the alarm goes off right away.
This is a huge problem if you want to use the Alarm. Already caused me to be late on several occasions(been having this bug since I bought it, no updates have removed it yet) So should I get a new phone or is a common bug?
Could you please send me your details in a PM, and will forward this for investigation.
Make a relevant topic and include the following.
Name:
Phone nr:
E-mail:
Country:
Operator:
Product(s):
IMEI nr:
Build number:
Have you installed Automatic task killer?
Uninstall all such apps, they are useless.
Don't forget to mark Correct Answers & Helpful Answers
Even with 0 apps I got this problem.
and the one I did use was Wordfeud.
weeks after I installed one called "Tilbuds Aviser" danish thing.
If tipo breaks down from 0 apps and it goes even faster downhill with just 1 installed and it complete breaks with the second. Something is wrong according to the logic I can think of.
Hello,
I have just the same problem with a Xperia Miro, the same.
Clock doesn't updated, alarms...
Thanks in advance.
