It takes more than 2 hours to charge even 80 % of the battery, i dont see any room for sony to imrove or rectify it on this device, Would be more than happy if this can be solved
It depends on the charger's(adapter's) output.It is normal to charge slower with a not so powerful adapter.
ok
i have got the solution
i too face the same issue today in the morning and fixed it my self
its very easy
first of all remove the charging cable from phone
and press vol + and power key togather and keep pressed untill phone shut downs( phone will restart)
by doing this you will have a hard restart (dont warry nothing would be changed every thing wod remain same)
after getting home screen reconnect the charger
TADAA
done
do it and report back
After this process, how much time it takes to charge the phone from 0 to 100?
I am currently using Xperia Z1's charging adapter which is 1.5 Amp and it charges my phone in 2 hours flat!
2 hours sounds much better.
