charging time duration in xperia M dual (100% charge)
shahi
Hi. how long is the charging time duration in xperia M dual (Full charge)?
my xperia M dual has normal and good battery function and charge in approximately 3 hour (about 2:40 - 2:50) . charger is EP800 and its tepid (not very warm) in charging period . are these normal ?
thanks
3 REPLIES 3
profile.country.RO.title
_alexdon_
A full charge from 0-10% to 100% is not standard,sometimes it charges faster,sometimes not.It depends on several parameters:if you use the phone while charging,if the voltage is constant,if the charger is for fast charging.But if you say 2-2 and a half hours for a 1750 mah battery it is ok.
alexdon
shahi
You know ,I use original charger that its EP800 .  EP800 has 850 mA output, I heard that EP800 charge slowly because of output. Unfortunately Sony site hasn't any information about this . So in attention to your commandment , it should be normal in spite of that its more than 2 and half hours !
_alexdon_
Yes,for the output of the charger and the capacity of the battery(1750) I say it is good.My Xperia P charger is fast,1500 mah output.
alexdon
