Hi, last sunday the battery of my Xperia Sp have ended whole. Then, I put it to have a charge. After 1 hour I picked up it and I saw that it doesn´t charge anything. I tried about 30 minutes make a charge and I wasn´t successful. After it, my cellphone doesn´t charge turned off, only turned on. Does anyone know what can be?
Hi, last Sunday the battery of my Xperia Sp have ended whole. Then, I put it to have a charge. After 1 hour I picked up it and I saw that it does not charge anything. I tried about 30 minutes make a charge and I was not successful. After it, my cell phone does not charge turned off, only turned on. Does anyone know what can be?
How are you charging your phone?
Computer?
Sony's wall charger?
A different wall charger?
A different USB cable ?
Zulhamizan98,that is probably because you used too much power(like power gaming and too much online hours).Another reason is it might also be caused of using too much mobile data that drains power very fast.Under these circumstances,our smart phone had already "smartly" estimate how much hours left when you about to power gaming.So if you want to get like 4 Days++ with Stamina Mode ON quickly,first you must fully charge your phone,then turn OFF Stamina Mode and left your phone untouched around 12-16 hours.Well thats the fast way,another way is,you can use your phone as usual but avoid power gaming and avoid using mobile data frequently(for around a week or two).Sooner or later,the Stamina Mode will register around 4 days of Standby time.
Don't worry,i experienced it when i played NFSMW online using Mobile data for straight 4 hours.It made my standby time with Stamina Mode On to only 18 hours.But now,after using the "fast way",i had finally obtained 4 days and 4 hours of standby time with Stamina Mode On.
So next time if you want to power gaming,remember to play only 3 hours straight max with 10 minutes rest for each hour of gaming.
