Charging issue
M91khan
Charging issue
When I put mobile on charge it charges 40% and then it stops charge I am using lollipop 5.1 .... It's a software issue or hardware need help
3 REPLIES 3
xavinux
Enthusiast
Hi @M91khan
I suggest first run a backup of the device information as explained here. Then perform a system repair using PC Companion or Bridge for MAC. The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 80% battery. Switch off your phone and unplug from Pc (Hold volume up and power for around 10 seconds) Start PC Companion and select Support zone then Update my phone/tablet then in Blue Repair my phone/tablet and follow the on screen instructions - When prompted connect your phone still switched off holding volume down or back button - This should start the repair or reformat process. If you are using Windows 8/8.1 or a 64bit operating system then adjust the settings for PC Companion and run in compatibility mode and chose Windows 7 or XP. Keep us updated please.
M91khan
Phone charge too slowly. It takes 2 hours to charge upto 40% and then it stops.I just reset my phone but same problem.
xavinux
Enthusiast
Hi @Hi @M91khan
Please, try the suggestion I posted above and keep us updated.  I am at disposal for any question.
