Charging dock DK26
hafiz
Charging dock DK26
can we charge the phone using the dock if it's connected to PC?
17 REPLIES 17
just test it, no you can't
GeoffH
Enthusiast
it would be exactly the same as without the dock - all the dock is doing is holding the phone
the PC charge rate is not as high as the mains connection though
I'm trying different ports and computers but it does not work
hafiz
ok, thanks for your info guys...
anyway i'm still waiting to get the dock from an online store.. it's not comes with the phone here.. and it's so hard to look for a store with the dock in stock..
Is it OK to use a generic one? (not genuine from sony) ?
I haven't seen any non sony dock that will be compatible with the Xperia Z, if anything it will have an usb cable so you will have to remove the micro usb flap which defeats the purpose of a dock.
GeoffH
Enthusiast
strange, but anyway have a question
I have a gel type cover/case  on my phone and it has the charging contacts uncovered - will the phone fit in the dock with the cover on - is it a tight fit bare, haveb't got the dock yet but will report back when I get it
If it is too tight I will modify the dock and make it fit
you will have to modify the dock as there is a 2mm gap
benchong05
I just bought the DK26 and connect using a aftermarket cable of 3M in length but the phone did not charge at all though I am using the default charger which comes with the phone.
I have no issue when using the original cable and charger so not sure what is the problem?
there was another thread with info on this, I'll try to find it
