Charging bug after marshmallow
CAVOK
Unfortunately did the OS update...
Charging problem after OS update. Device charges up to appr. 70% then lights screen and keeps screen lit. Charging symbol shows charging. Device becomes hot. Tried various charging cables/plugs including original. Different behaviour, but in any configuration does not charge full (max. about 80%). Charging stops at appr. 80, as drain of lit screen seems to be equal to consumption.
With some chargers/cables device jumps from charging to non charging within every half of a second at or about 75% and then looses charge, stops "flickering" starts to charge again and at or about 75% procedure mentioned above starts again.
Tried also charging in safe mode, did not help.
Charging Problems started with Lollipop, then turned much better, but now very bad again. I fear that this behaviour damages battery! Best regards Michael
Thx for any help
@CAVOK
What if you repair the phone with XC and check again?
Xperia Companion (XC)
Software Repair Guide
