charger
bouliel
charger
hi all i put charger on . i have had it on for 40minutes it started at 12 percent fourty minutes later it still shows 12 percent.i go to settings phone says cahrging  12 percent is it realy charging or faulty charger
2 REPLIES 2
It might because of a faulty charger, have your charger and battery checked by your auth. service personnel
Jake-SonyXperia
This could be a software glitch, have you tried simply turning the handset off and then back on, have you also tried removing the USB from the charger adapter and removed the adapter from the wall socket?
