not matter what i try the lockscreen only shows the default live wallpaper HELP!!!!!
Have you tried settings-apps-all-xperia home,force stop and clear data? Restart and set a wallpaper again.
Do you have any taskillers or antivirus? any third party lock screen and/or home launcher ?
Tried it didnt work..... This all started after the 4.4 update if i am not mistaken.
No task killer only AVG Antivirus Free. everything is stock
You may need to perform a software repair using PC Companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
@rz07 were you able to resolve your issue?
for future reference
