Hai , I'm using Xperia M5 Dual less than one week but I encountered problem that I can't used memory card . When I move apps ti sd card the apps automatically send me error message saying that the apps was stopped and same goes to camera . If i set the the default storage in camera to sdcard the camera failed to save the picture the circle keep spinning .. I had reset my device , memory card and I also have latest software .. Any solution anyone .. Please .. I don't even know either sdcard or my device broken ..
Topic edited by Rickard
I'd suspect the SD card first, is it possible to test another SD card (preferably of a known and reputable brand)?
Did you format this SD card from phone before you start using it?
Yes , I did .. I love sony as well but since this happened to me ..
What's the specs of your SD cards (Size, brand, speed)?
I still suspect this SD card, if it worked after a format then stopped working then it might be a defective unit.
If you have access to a PC with a card reader i recommend that you test this SD card using a test software like h2testw. This software can write a known pattern to the card and then reads it back to check if the SD card stores data properly.
