Hello,
So yesterday I just solved my own issue of not getting any LTE signals http://talk.sonymobile.com/t5/Xperia-Z2/Z2-LTE-Not-Working/td-p/784021/jump-to/first-unread-message
Today, I followed the advice of a user to restart the phone using PWR + VOL UP buttons to get the smoothness back. I did just that, phone became smooth again with the phone registering on LTE network.
But what happens now? I can't connect to Mobile Data AND can't make phone calls. I can run USSD code to check my balance and can receive calls just fine but cannot make phone calls.
Any ideas? Do I need to reinstall the FW again?
Model: D6503 FW: .314Ok so I tried repairing again via PC but to no effect. The signal bars do come up as full, calls can be received but cannot be dialed nor mobile data can be used...
This thread can be closed. Thank You
At least tell us what you did.
Some users may have a similar problem
My network carrier first confirmed that everything was fine at their end and that it was the handset issue (I never believe them anyway).
But afterwards it was confirmed that it was indeed an issue with the network operator and that they had fixed the issue...
