hello all,
I am unable to use the camera quick launch function, even when setting as 'launch and capture'.
correct me if i am wrong, to use the camera quick launch function, i believe is it to press and hold the camera button right?
is there any other setting i need to make, other then setting it to 'launch and take'
thanks
Hello!
Are you sure you really pressed the button completely? Another guy in another forum had the same problem cause he did not press the button totaly. The button has two states which you have to press and the second one is quite crisp.
will try it soon, another qns...
jus wondering if anyone face the same prob as me, when i tried to take photo using the button at the side, it focus then after awhile it didn't take any photo.
Izzit cos the environment is dark? or i didn't press the button hard enough?
Yes having the same problem.
if you move the phone after half pressing the button, the acquisition process starts again
Since i have a silicone cover it's quite difficult to press completely the button without moving the phone
So i will use the button on the display, much easier
ic...yea i resort to use the one on the screen,
jus wondering if you have the 1st problem i stated also?
which problem? with quick launch?
because of my cover i have a lot of problems pressing the camera button so it wouldn't be quick anyway
But seems to work
yea...seems like its my own fault for not pressing it hard enough...
I know this solution its a bit low tech, but since it's a silicon case you can cut a little bit around the shutter that way you can press it completely
It's ok i will just use the screen button
using the shutter has advantages, as you can focus easier
