camera problem with some apps
manrojit
when ever i use some apps that uses camera( front facing)....the displays doesn't show full picture...only certain part only show the picture...any one ...plz help...
another problem is with browser
I opened the browser and when i click the link or adress bar...i get the guided kind of voice ...how to disable it?
Karan_wolverine
For the first problem, the app you are using may have dedicated area for front camera display, may be that is the only area where your app has allocated space to display the secondary camera content. If you use standard camera application and choose secondary camera, it works fine. Try it.
For the second one, i too had this problem. First try this. Go to Settings>Accessibility> and turn off the Talkback option if it is On. If it is still reading your contents, go to Settings>Apps>All> and search for PICO tts, select that one and disable this service by selecting Disable.
