Hey everyone,
Yesterday my cellphone went crazy, the CAMERA APP doesn't stop starting by it self. I can't do anything about it, the camera automaticaly starts up and keep taking photos.Even when the cellphone has the screen blocked.
So i got in contact with CHAT SUPPORT on Sony Mobile.com and they said it was a "software conflict " and that I should look for an authorized support in my area).
And i didn't work....does someone know what is happening ? what should i do ?
I saw in a facebook board someone had the same problem yesterday...i don't know what to do ....
You may need to perform a software repair using PC companion.The process will erase all internal memory.You might need to charge your device for about 1-2 hours before so the device has at least 60% battery.
Open PC companion->support zone->phone/tablet software update->repair my phone/tablet blue highlighted.Follow the steps given,do not connect your phone until prompted to press volume down while plugging USB cable.
If the above does not help,you need to stop by a sony service as it may be related to a defective button.
i've done it already,it didn't work...
In this case,you have to stop by a sony service:
