camera problem after ICS (xperia mini pro)
just updated my xperia mini pro to ICS few days ago...
now every photo i shot with the resolution 5MP 4:3 got a wrong thumbnail...
but photos shot under the other resolutions (3MP 16:9, 2MP 4:3, 2MP 16:9) have no problems
and their right thumbnail as before ICS...
the wrong thumbnail seems not to be a problem of the viewing software on the mobile phone
because uploaded on the pc the wrong thumbnail is still there.... Slightly_frowning_Face
has anyone the same problem or a solution?
thx
e.g. thumbnail and its original
12 REPLIES 12
Yes. You're correct "c4pt41n". First time I've upgraded to my phone to Android 4 via SUS. After I discovered this problem I did a Master reset but problem was still there. Again I repaired my device using SUS but problem not solved. Hence I think there is problem with new camera software of Android 4.
Dear Johan,
     Thank you for your reply. but I kindly request you to do a practical test with a Xperia mini pro on your hand with above mentioned settings. (Image Stablizer ON and resolution set to 4:3 (5 MP)). I'm sure you can experiance this problem too.
Kevin_H
Same problem with my xperia mini pro !
I am facing the same problem. The thing is, if you use QuickPic, it will show a blurred image in your mobile itself. If you view it through the galary, the thumbnails are displayed correctly. However, after connecting it to PC, again the image appears blurred out. If the image stabilizer is off, it doesnt cause any problems but that tends to give a very poor quality image. Hope Sony comes with an update soon Slightly_smiling_Face
