Camera not working - HELP
crossdeath
Hello everyone!
I have an Xpera M and my camera isn't working. When I open the camera app it says "Camera not available" or "Camera has stopped working". This started happening around September or so, and since, I've tried to do everything to fix it, but no luck. I installed a new software update, custom ROM, bootloader unlock, clear camera files... I even tried sending it to Sony Center but they didn't want to fix it because of the bootloader. I didn't drop my phone or anything, so I don't think it's a hardware issue. Actually, today when I opened the camera, it was working fine, but only for a few seconds. Can someone please help me? :smileycry:It's really annoying when you can't use your camera Thinking_Face
Thanks in advance!
13 REPLIES 13
goelaakash90
Only thing i can suggest is that you should try to flash a stock firmware version.
See if it works.
and make sure it is a clean install.
crossdeath
That's what I already did after I installed a custom ROM to see if that will make some difference, but whatever I do, it still doesn't work Slightly_frowning_Face
crossdeath
Hello again!
I can't believe it! My camera is working now! It look like CM Securitiy solved my problem, I turned on the option to take a picture of the person who enters the wrong password three times. It took my picture using the front camera, and after that I opened the camera app and it was working. Also, when it asked me whether I want to enable geo-tagging, I selected 'no'. I hope this could help somebody else with the same issue Slightly_smiling_Face
afr0diti
Hello,
i have the same problem, i tried everything above and even the face lock does not work:/
i'm not in my homecountry so i cant bring it to a sony support, does anyone have any other suggestion?
